100% VLM ???
I almost padded this one Doah, customer has rentals he happens to be a doctor from India.
Has a African American handyman who cleans up and paints the property.
I guess drop clothes aren't necessary when you hire a warlock to fix all your mistakes.
I blocked the guy a few years ago cussed him out for wasting my time, a year later he's back and it's been slow so guess what.
Yeah this!
View: https://youtube.com/shorts/YqTLQc3J-ew?si=0QOx9dvYUnHrIYGf
Reactions: SteamwayPro
SteamwayPro
George
Yeah this!
Excellent Work
That looks like 30-40 year old nylon
Old nylon usually cleans up easily
How long did it take just to vacuum
Excellent Work
It's older polyester lots of reverse nap,
Too long almost killed my oreck
Bryce C
DFW
Bryce
Thank You I get very little respect here but I kinda like it that way
I like the challenge and I like being the outsider
Well you sometimes mock other cleaners who are thoroughly flushing soil and allergens out of residential carpets with truckmounts. I think we all get that you can make a carpet look good with VLM, and it is ideal for commercial work.
You feel great about using it in residential, good for you. I feel great about setting up, thoroughly cleaning, and breaking down my equipment in a little over 60 minutes on my small residential jobs, and not hauling a 100lb machine up steps. To each their own way, as long as you live in the presence of a clean conscience and your customers receive a valuable service, go for it. I love what I do with my 300 horsepower jedi extractor, and the assortment of other equipment I utilize on every job. My customers do too. Cheers. Here is a review I got today:
SteamwayPro
George
Nice Review. Congratulations
I love VLM !!!
Reactions: KevinL
SteamwayPro
George
A Oreck vacuum is not made for that kind of abuse
You need the KING of Vacuums a Kirby for jobs like that or a small Shop Vac.
I always have a 8 gallon VacMaster on the Van just in case I run into something like that. I rarely use it but glad to have it when needed. I only used it one time this year. Yes after the Shop Vac you gotta then use a REAL vacuum like a Kirby. Shop Vac picks up all the big crap so you vacuum doesn't get clogged.
I also have a Shark Kirby and Pro Team on my van. I use the Kirby the most then Shark
I don't even know why I have that Pro Team on my Van anymore. I haven't used it for over a year. It's a good vacuum on CGD but for thick residential carpet it's disappointing. I do like the wand. It's easy to use but Shark has a wand and vacuums residential carpet better
Back in the day some still do use a sanitaire with a magnet stop to catch metal.
My oreck has had the plastic fan replaced with a metal one.
Still I prefer my work horse on these jobs it's not a pass thru
SteamwayPro
George
Yup you gotta use what works for you not what works for someone else
One job today. I've been going to this house for about 25 years
30 year old nylon
Another successful job using Hydrox on Residential
Zee
30 year old nylon
Do you always leave the carpet in that sort of messy look, or do you groom it out nice and even?
I'm simply curious...I'm not attacking you.
Also what kind of camera do you use? (Your pictures, often, appear quite blurry)
Do you have a YouTube channel? I want to see your process...
Again, I'm not attacking you...I was once a strictly VonSchrader guy (late 1990's) that transitioned to full on high heat, high flow, high flush, truckmount cleaning (better part of the first 20 years of the 2000's)...but in the last 6-7 years I'm pretty much totally vlm (crb, Orbot sprayborg, Vibe, Cimex etc - have not touched the truckmount in my other van for at least 7 years)
Again, I'm not attacking you...I was once a strictly VonSchrader guy that transitioned to full on high heat, high flow, high flush, truckmount cleaning...but in the last 6-7 years I'm pretty much totally vlm (crb, Orbot sprayborg, Vibe, Cimex etc - have not touched the truckmount in my other van for at least 7 years)
Not sure i can get that high....!
Reactions: BIG WOOD and Zee
Whatever ya blocked it the first time
Have you even HEARD of this?
I really thought EVERYONE has heard of this by now......we've been tracking this interstellar object close to a year now.....
PURPOSE:UNKNOWN
However my belief is.....they have to eradicate this pesky species that are about to introduce a radioactive substance into an otherwise perfect creation......
AND MORE-FURTHER......YOU....should realize if you haven't learned of this phenomenon......how many other Things are you un-aware of????????
SteamwayPro
George
Another cleaner that realizes you don't need to FLOOD Residential carpet with gallons of water to clean it today
You can do it that way, but there are other ways, better ways, and MORE profitable ways to clean carpet today
Yes HWE uses and WASTES many many more gallons of water on Residential carpet compared to VLM
LESS water MORE agitation !!!
Reactions: KevinL
SteamwayPro
George
Yes I leave the MESSY Look and I like it
If I thought there was something wrong with the MESSY Look I wouldn't post pictures
I don't worry about perfect groom lines. When the customer starts walking on the carpet those lines will disappear fast. They're not deep lines
I use a 10'' CRB with soft brushes. That carpet is thick nylon and the lines are mostly just on the surface because the CRB is light and has soft brushes. A carpet brush/rake leaves deeper lines than a 10'' CRB with soft brushes. A 10'' CRB grooms the carpet better than a Brush or Rake. My opinion
I never get any negative comments from customers but do get criticism from other cleaners. If I start getting negative comments from customers that's when I will change my opinion on the MESSY Look
I'm more concerned with getting the carpet clean and dry than groom lines
I like the MESSY Look !!!
Reactions: KevinL and SamIam
SteamwayPro
George
No You Tube Channel and I just use a Camera on my Phone
But I'm just taking pictures to post here. If they're not perfect it doesn't matter
I love VLM !!!
Reactions: KevinL
Not gonna start this debate all over again, but if you hwe, you know you didn't have to #flood most carpet to get it clean. Chems and agitation are doing the same thing you're doing following up with an additional step. Some don't do that🤷🏼‍♂️
jack zerkie
Yep starting to likeVLM can't pull the hoses in anymore trying to to sell truckmount van and other equipment I was doing good for a while but have run out of steam not in the truck but ME hope to make it to January to 84 so I'll just do small jobs to help pay bill.No retirement but in stock market and NOT good there but there is light at the end of the tunnel. I just have to find the tunnel.
