GM Brakes
rhyde
Portland, Oregon
rhyde
Bad rotors or too much heat build up due to insufficient break system for the weight your hauling....are you running through pads much faster?
I'd run the van over a scale just to see how much weight you have that should tell you alot right there . if you are under the GVWR then i'd think it's bad rotors and slotted rotors should be the fix at or over GVWR then i would think your break system isn't sufficient to handle the weight.
If that's the case you need a larger break system rotors and calipers.....GM perhaps or after market $$$.
or you could Jerri-rig it and hope the breaks don't fail and kill people or yourself it would probably take a few hours for the fire department to remove the TM from your colon :shock:
