- Oct 16, 2006
- Name
- Caesar
On the newer Butlers.There is a quick removal insert in the center hub.
I believe,if that hub assembly can be removed.
You could take a 2.5 inch hose,about a foot longer then the clear one standard on them now...
Insert it into the reel hub center,from that you add a 2.5 inch swivel koolkuff.They make the only 2.5 swivel ,I know of ?
Then hook your 50 footer to that.
The swivel if it can get into the center of the hub should take the place of the Butler swivel?
Or If you can do that,you could mount a second reel in the back.As in some Butler corp pictures.
Then have your 50 foot only on that,with the main reel dead and for 2 inch (or more ) storage? Possibly more then 50?
But I need to see a new reel to see if any of the hub can be disassembled.
I am in the process of having my 2 inch elbow on the waste tank.Hole sawed an a new 2.5 inch elbow,and metal nipple put in.
At that point,I can run a pair of 2.5s to a wye connector.Coming down from the water tank areas.
But regardless of the fact,you really need a second vacuum port installed in either side door or rear door.
One 2.5 and the solution hose are tight fit.So mine when done should have vac out the back and solution to the side...
