Vortex waste tank filter set-up
captaincarpet
Kennesaw Ga.
Thomas Cermak
-Can someone please post a few pictures of the filter canisters on a Vortex. I am curious how they are mounted to the tank.
I am planning on adding a third filter canister and would like to see how it fits. We will be going to 2.5" hoses and I need to run 3-2" to the manifold to have enough vacuum. ( I think this is how Mikey's set up is).
Thanks!
I actually do not use the lint filters.
Because the V tank drains so well I use a pool filter to catch the crud on the way out.
If I used my APO then I would have to pre filter.
most I have seen only come with 2 filters hanging on it I am sure the way the tank is set up you can add the third one
each filter is independent on the tank
from each ball valve
I have removed mine also but if you got to the vortex web site there are pictures of the set up
I can give you pictures of how the filters look if needed but I don't have any of why they were hanging on the tank.....
captaincarpet
Kennesaw Ga.
Thomas Cermak
I have been all over the Vortex site and can't find any pictures of the waste tank and the filters to see how they are set up.
Since I have only 2 filters I'm sure the set up is different, and since I'm going to go to 3, I'd like to see how they are done.
Thanks!
N GA
BradFenstermaker
That is someone else's truck but I think they are the filters from our industry. Either mesh screen or a sack filter.
I can find out if you like.
captaincarpet
Kennesaw Ga.
Thomas Cermak
I will post pictures of what I have currently( I will try to take them and post them tomorrow), perhaps that will clarify what I am trying to do.
Thanks for the help!
Tom
adamh
Nampa Idaho
Adam Hale
This is what I have done. I have the two 2.5" hoses and the one 2" coming from the tank going into a filter box. Then two 2.5" going out the truck. I have taken the elbows out.
