Auction Ronald McDonald Scottsdale Auction #5 Pro's Choice- “Vapor Kit.” VDT-4200 and 3 bars
Pro's Choice- “Vapor Kit.” includes a VDT-4200 Vapor Tunnel along with 3 vapor bars.
http://www.proschoice.com/vapor-pro.html
An amazingly simple vapor generator that is best described with two words, ”Performance & Economy”. This machine will match or outperform machines costing more than 10 times as much.
When working with Dry Vapor it is best to have distributed application so you won’t have high concentrations of vapor at the source and minimal concentrations at a distance. The VDT-4200 is ideal because it is inexpensive to place multiple units at a site and the VDT-4200 is very light and easy to attach to walls or set on nearly any surface. Add to this the fact that it runs on safe low voltage and you have a winning combination.
All proceeds from this auction go 100% to RMHC.
Payable by check only, made to out to Ronald McDonald House Phoenix
Serious bidders only. Prizes will be sent out directly (at no charge unless noted, from the donor once you check has been received by me.
Opening bid is $$25 w/ minimum $5 increments
Retail value is $100
Free shipping to the lower 48
Auction is over September 24th at 6PM PST, highest bid wins at 6PM sharp.
