Lucas hydrologic fluid for water pumps??
Wi
Keith
I swore someone (Lockhart) mentioned using it? Or are most of you using straight non detergent 30 weight?
GeneMiller
Boca Raton
gene miller
I always use the pump manufactures fluid. I just bought 2.5 gallons of general pump oil. 85, which is pricey but cheap insurance in my eyes. I also used aeon pd in my blowers.
Gene
Reactions: Able 1
Mike Draper
I run Lucas in everything and that includes mixing it in my pump with oil. Why not, it makes the oil slicker and doesnt break down as quickly. Only time I wont use it is when an engine is breaking in. Its so slick the rings wont seat properly. Great stuff though.
Reactions: Able 1
dgardner
Phoenix, AZ
Dan Gardner
Reactions: Able 1
GeneMiller
Boca Raton
gene miller
2. 5 gallons?
Are you changing it every month?
Why so much?
It doesn't go bad on the shelf. I'll have this machine a while so why not buy in bulk. Always been my way. The pump holds 40 oz. you should see how many cases of transmission fluid I have. I also buy my filters by the case.
Gene
