Fresh water hose
Chads
Whats everbody running, I need to upgrade mine and I'm looking at goodyear water hose but not sure I need that much and I hate hoses that kink on me all the time I dont have a water hose reel .
Chad;
We use 350 PSI thermoplastic rated up to 160°.
Most of our TM's have triple reels.
Good in most locations except for extreme cold weather.
Farenheit251
For single wand you can go with half inch quality hose from a hose store. Well worth the money and much easier to work with and store. I think some guys were converting air hose with end adapters. Might freeze quicker in cold climates.
Mike Draper
I use two 50' rolls of anit-freeze coolant line. I think it's 5'8 inch in diameter and rolls up perfectly on my hose reel. I think it's like $20 bucks for 50'.
We carry 60' sections of 3/8" air hose on portable cord reels. Garden hose fittings on the end with brass ball valve and brass quick couplers on each section. Light and easy to handle and a breeze to wrap up.
Chads said:
Cobb you got any pics
dude, I know Larry wants to sell you and everyone else some hose, (which i don't have a problem with)
but you don't have a hose reel.
thermal plastic ain't for you....trust me
you need a supple hose you can coil on the ground.
Rubber is the way to go
here's another tip; ALWAYS coil it the same way from the same end.
AND always drop a coil at a time as you walk to the spigot.
Your kink and coil probs will be few and far between if you do it that way.
Keith
This one is sweet but it's $300... Probably last you forever though.
$100.00 for this one.
I used to do it the same way you mention but it's a pita doing it that way. I had a fire man teach me the way to coil a hose and not kink or get tangled even if you throw it up and out in the air. Saved my a$$ a lot of time doing it that way. I don't have a hose reel and most of the time have to run a portable. Just hook up the QC and when you start to pull the hose, it uncoils itself without any loops.
It's a over and under technique that makes it work. It works with solution lines, hoses, cords but NO vac hoses.
